16 years ago
to find out the number of "1"
hi,everyone
i need to find out the number of "1" in a input (a),
now ,i thik i could add every bit of input (a) to get the resut,
just like : assign b=a[0]+a[0]+a[1]+a[2]+a[3]+a[4]; -----code(1)
so , if a==5'd10==5'b01010 then b=2 , it's right
but ,now, the width of a is 2023 ,it is too large.
so , for me ,it is a big trouble for me to write like code(1) ,it will cost too much time.
so i wright like this:
module jj(data_in,weight_out);
parameter IN_WIDTH=10;
input [IN_WIDTH-1:0 ] data_in;
output [11:0] weight_out;
reg [11:0] a;
always @ (*) begin
integer i;
for(i=0;i<IN_WIDTH;i=i+1)
a<=a+data_in[i];
end
assign weight_out=a;
endmodule
but , this logic is not right.and a combinational loop occurs.
any convenient and right method?
thank you!
    A nice way to do this is by writing a recursive function.
    You first extend the vector with '0's so that the number of bits is a nice binary boundary, in the case you give 2048. You then call the recursive function which calls itself for the two halves. This continues until we have just 2 bits left.
    This will generate a nice tier of adders with the shortest delay and if you code it carefully minimal logic resources.
    Unfortunately I don't know Verilog (yet, but I ordered my first book on it).
    In VHDL it would look (somewhat) like this:
    function number_of_bits( src : std_logic_vector) return natural is
    begin
    if (src'high = 0 ) then
    -- we're down to a single bit
    if (src(0) = '0') then
    return 0 ;
    else
    return 1 ;
    end if ;else-- we can split
    return number_of_bits( upper_half(src) )
    + number_of_bits( lower_half(src) ) ;
    end if
    end function number_of_bits ;
    Opposed to what a C-program or so would do, the HDL compiler will unroll the recursive loop into a nice tier of consecutive adders, in this case 11 layers and 2047 in total.
    In VHDL, you can use "variable" for counters
    you can use "function" or "procedure" to find out the number of '1'. This function will be something like
    a<=a+data_in;
    end
