15 years agoTo build a FIFO using SRAM
Hi, I would like to build a DCFIFO using a SRAM chip on DE2-115. Any idea on where i should start? I know SRAM reads and writes on a different clock cycle as the dataIn and dataOut share t...
15 years agoHi Michael,
--- Quote Start --- My ADC is sampling at 65MHz. i am trying to capture 2MB(1024000 samples) of ADC data and send to through QuickUSB at 30MB/s, and graph it on my laptop using Matlab. --- Quote End --- What is the bit-width of the ADC? --- Quote Start --- Do you think NIOS 2 is capable of handling 65MHz data? or the SRAM controller is running at slower speed than 65MHz? --- Quote End --- The NIOS II never actually touches the ADC data, its just there to coordinate movement of the data. The key design parameter is whether you can find a memory target that can maintain a sustained data transfer rate of 65MHz x ADC bit-width. You'll need to see whether the SRAM or SDRAM on the DE-115 can handle that data rate. Cheers, Dave
