16 years agoTip/suppornt on debugging a VHDL project on Altera
Hi I have some experience on hdl coding, but none on FPGA debugging. (which does not necessarily mean the problem may not be in my HDL coding... ;) ) I´m facing a weird (imho) situation ...
16 years agoHello everybody
Thanks for answering that, and sorry if my mistakes were too basic. Here follows the whole code for the process, if you may take a look. The signals are touched just after "WRITE OPERATION" comment. In the meantime, I´m going to check the rst in the sensitivity list and see how it works. Thanks again -- Flash protocol handling process flash_process(clk) begin if(rst='1') thenflash_data <= "ZZZZZZZZ"; flash_opcode <= X"0"; flash_addr <= X"000000"; int_flash_en <= '0'; flash_erase_running <= '0'; flash_read_running <= '0'; flash_write_running <= '0'; etcmiv_data <= "ZZZZZZZZ"; etcmiv_data_rdy <= 'Z'; etcmiv_data_rdy_detected <= '0'; [/INDENT] -- ERASE OPERATION elsif(rising_edge(clk)) thenif((etcmiv_flash_erase ='1') or (flash_erase_running= '1'))then [/INDENT] if(etcmiv_flash_erase ='1') then -- first time [/INDENT][/INDENT] flash_erase_running <= '1'; flash_addr <= erase_addr; case(int_etcmiv_opcode) is [/INDENT][/INDENT][/INDENT] when ERASE_INIT_PARAM_T | ERASE_DEF_PARAM_T | ERASE_AGC_T | ERASE_BPR_T => [/INDENT][/INDENT][/INDENT][/INDENT] flash_opcode <= ERASE_4K_OP; [/INDENT][/INDENT][/INDENT][/INDENT] when ERASE_NUC_T | ERASE_MENU_T => [/INDENT][/INDENT][/INDENT][/INDENT] flash_opcode <= ERASE_64K_OP; [/INDENT][/INDENT][/INDENT][/INDENT] when others => NULL; [/INDENT][/INDENT][/INDENT][/INDENT] end case; [/INDENT][/INDENT][/INDENT][/INDENT] else -- not first time, erase operation started [/INDENT][/INDENT] if((clk_spi_flash = '1') and (int_flash_en = '0'))then -- flash_en should change only on a sck falling edge [/INDENT][/INDENT][/INDENT] int_flash_en <= '1'; [/INDENT][/INDENT][/INDENT][/INDENT] elsif(flash_done = '1') then [/INDENT][/INDENT][/INDENT] int_flash_en <= '0'; flash_erase_running <= '0'; end if; [/INDENT][/INDENT][/INDENT][/INDENT] end if; [/INDENT][/INDENT] -- WRITE OPERATION elsif((etcmiv_flash_write = '1') or (flash_write_running = '1')) then if(etcmiv_flash_write = '1') then -- first time [/INDENT] flash_write_running <= '1'; flash_addr <= write_addr + operation_counter; flash_opcode <= WRITE_FPGA_OP; [/INDENT][/INDENT]else -- not first time, write operation started, but wait for data_rdy [/INDENT] if((etcmiv_data_rdy = '1') and (int_flash_en = '0')) then [/INDENT][/INDENT] etcmiv_data_rdy_detected <= '1'; end if; [/INDENT][/INDENT][/INDENT] if((clk_spi_flash = '1') and (int_flash_en = '0') and (etcmiv_data_rdy_detected = '1'))then -- flash_en should change only on a sck falling edge [/INDENT][/INDENT] int_flash_en <= '1'; flash_data <= etcmiv_data; etcmiv_data_rdy_detected <= '0'; [/INDENT][/INDENT][/INDENT] elsif(flash_done = '1') then [/INDENT][/INDENT] int_flash_en <= '0'; flash_write_running <= '0'; [/INDENT][/INDENT][/INDENT] end if; [/INDENT][/INDENT] end if; [/INDENT] -- READ OPERATION elsif((etcmiv_flash_read = '1') or (flash_read_running = '1')) then if(etcmiv_flash_read = '1') then -- first time [/INDENT] flash_read_running <= '1'; flash_addr <= read_addr + operation_counter; flash_opcode <= READ_FPGA_OP; flash_data <= "ZZZZZZZZ"; [/INDENT][/INDENT] else -- not first time, read operation started [/INDENT] if((clk_spi_flash = '1') and (int_flash_en = '0'))then -- flash_en should change only on a sck falling edge [/INDENT][/INDENT] int_flash_en <= '1'; [/INDENT][/INDENT][/INDENT] elsif(flash_done = '1') then [/INDENT][/INDENT] int_flash_en <= '0'; flash_read_running <= '0'; etcmiv_data <= flash_data; etcmiv_data_is_ready<='1';etcmiv_data_rdy <= '0'; flash_data <= "ZZZZZZZZ"; [/INDENT][/INDENT][/INDENT] end if; [/INDENT][/INDENT] end if; [/INDENT] -- NO OPERATION else if(etcmiv_ready_to_get_data = '1') then [/INDENT] etcmiv_data_rdy <= '1'; etcmiv_data_is_ready <= '0'; [/INDENT][/INDENT] elsif((etcmiv_data_rdy = '1') and (etcmiv_data_rdy_dly = '1') and (flash_data = "ZZZZZZZZ")) then -- assure etcmiv_data_rdy is active and stable, to assure etcmiv already got it [/INDENT] etcmiv_data_rdy <= 'Z'; etcmiv_data <= "ZZZZZZZZ"; [/INDENT][/INDENT] end if; flash_data <= "ZZZZZZZZ"; flash_opcode <= X"0"; flash_addr <= X"000000"; int_flash_en <= '0'; flash_erase_running <= '0'; flash_read_running <= '0'; flash_write_running <= '0'; [/INDENT] end if; -- operation end if; end process; -- flash_p
