15 years agotiming simulation
bonjour
I try for one day to do a simulation timing The project is only a count16 write in VHDL the RTL simulation is ok but in Gate Level Simulation every times are set to 0ps and waves are like a RTL simulation. (no delay between clock and outputs ) I forget something ... I use Quartus10.1SP1 web edition with modelsim Altera starter 6.6d and the device is MAXII can you help me? thanks3 Replies
I managed to include sdo file and everything works perfectly now.
I have much to learn ... thank you Pierre - Altera_Forum
I use NativeLink
effectively I don't include the delay file count16_vhd.sdo how can I do? - Altera_Forum
are you running the gate level simulation yourself or with NativeLink? are you including the delay file (.sdo?) in your simulation?
