manpreet_1604
4 years agoTiming Requirements not met
Hi All,
I am using Altera CPLD "EPM7064" as a Replacement of Atmel "ATF1504" the original code was generated and tested for ATF1504 in "pro chip designer tool" using Verilog, when the same code is...
sstrell
4 years ago1) Do you have top-level I/O ports named "pulse" and "pwmin2"? The warnings are saying your .sdc is not finding these ports.
2) You can safely ignore the parallel compilation warning. I doubt a design like this takes a long time to compile.
3) The latch warning is because you are probably improperly coding registers. Can you share some code?
