15 years agoTiming requirement not met after increasing NIOS frequency
Hello, We are designing a system that is successfully generated in SOPC builder and compiled in Quartus II. The system clock is 75 MHz and we need to speed up the NIOS II processing powe...
15 years ago --- Quote Start --- Please use the "timing design advisor" to see what you can do about it. You can find out more in the user manual --- Quote End --- Thank you for your advice, I'll try to follow your suggestion and try the timing advisor. Kind Regards
