16 years agoTiming Question
Hi everybody, I'm new to these forums.. the community seems helpful. Hopefully someone will have input on my question, and hopefully I can help others. So I'm working on an MAXPLUS7128 SLC84-1...
16 years agoI am not clear about your issue. is it timing of serial data with its clk? or serial to parallel conversion inside cpld?
for serial data out transmission you will need to generate your serial data and its serial clk in same process.The process being clked by another suitable clk. normally your counting to be at twice serial clk speed. A good practice is make clk transition in the middle of data time slot.
-- on the clked process
case count is
when 0 => seial_data <= reg_bit(0); serial-clk <= '0';
when 1 => serial_data <= reg_bit(0);serial_clk <= '1';
when 2 => serial_data <= reg_bit(1);serial_clk <= '0';
when 3 => serial_data <= reg_bit(1);serial_clk <= '1';
