Timing error on Arria 10 PCIe core design
I understand that removing .sdc files will remove constraints; but I went ahead with this approach in order to eliminate any possible conflicting constraints, based on your response of 3/4/20.
Regarding ignoring the timing errors, I can not do that, because the errors are not confined to the reset signal; theare are also datapath errors, such as:
-0.571
qsys_design.synth_qys_inst.hchip_blob_inst|pcie_wrapper_inst|u0|pcie_a10_hip_0|pcie_a10_hip_0|g_avmm_256_dma.avmm_256_dma.altpcieav_256_app|read_data_mover|avmmwr_burst_cntr[0]
qsys_design.synth_qys_inst.hchip_blob_inst|pcie_wrapper_inst|u0|pcie_a10_hip_0|pcie_a10_hip_0|g_avmm_256_dma.avmm_256_dma.altpcieav_256_app|read_data_mover|rd_status_fifo|fifo_reg[6][8]
qsys_design.synth_qys_inst.hchip_blob_inst|pcie_wrapper_inst|u0|pcie_a10_hip_0|pcie_a10_hip_0|wys~CORE_CLK_OUT
qsys_design.synth_qys_inst.hchip_blob_inst|pcie_wrapper_inst|u0|pcie_a10_hip_0|pcie_a10_hip_0|wys~CORE_CLK_OUT 4.000 -0.199 4.350 1
And I don't understand what you are saying here:
removal/recovery violation for reset signal that come from external can be safely ignore. This is because the IP already synchronizing the reset
All of the timing violations I am seeing are within the IP core, and they are clock-clock violations which only occur (by definition) with synchronous signals.
