Timing error on Arria 10 PCIe core design
I am running QPP version 18.1.0 Build 222.
A few days ago I tried to partition and floorplan the design, but I was getting errors, including:
Error (14566): The Fitter cannot place 1 periphery component(s) due to conflicts with existing constraints (1 clock core fanout(s)). Fix the errors described in the submessages, and then rerun the Fitter.
It's not clear exactly where that error is occurring, but I did declare that reset signal from the PCIe core as a global. If I remove all of the Logic Lock regions, the error goes away. I will have to experiment a bit to find out which partition causes the problem when it is locked down.
I just did a build with some of the design floor-planned (but not the PCIe core), and the worst-case negative slack is now under 700ps. Here is a screenshot of chip planner; the bright green is the PCIe/DMA core.
That thing takes up a lot of space.
