Seadog
6 years agoTiming error on Arria 10 PCIe core design
I have an Arria 10 design with a PCIe core (hard-IP, 8 lanes, gen 3, Avalon memory-mapped, w/ DMA). The only timing errors I am getting are related to the reset generated by the PCIe core. The rese...
BoonT_Intel
6 years agoI see the negative slack is more than 1ns (-1.119), it is unlikely due to place and route issue (usually place and route variation only give small timing difference). But looks like it is due to some extra constraint or routing that cause the issue.
So, may I know what is the Quartus version that you using? Maybe I should try in the quartus version and see if give worsen timing.
