17 years agoTiming Contraint on latch
Anyone knows how to constraint the latch related circuitry? I attached a pdf that show the diagram. The clock is running at 10MHz and the timing requirements from input to output is 80nSec.
17 years agoI know using latch is not good design and do not want to use. Unfortunately, I must use it for my application. I need to find out how I can constraint these latch. I was thinking of using set_max_delay, but I'm not sure whether this would do it since set_max_delay is used for combinatorial logic path.
