17 years agoTiming Contraint on latch
Anyone knows how to constraint the latch related circuitry? I attached a pdf that show the diagram. The clock is running at 10MHz and the timing requirements from input to output is 80nSec.
17 years agoWhat is the purpose of this latch? Generally, using latches is not good design practice.
--- Quote Start --- Anyone knows how to constraint the latch related circuitry? I attached a pdf that show the diagram. The clock is running at 10MHz and the timing requirements from input to output is 80nSec. --- Quote End ---
