SK_VA's avatar
SK_VA
7 years ago
Timing constraints to asynchronous output
I have outputs from one FPGA to another FPGA. Outputs are clocked out of one FPGA and is completely combinational in the other FPGA. Can I set false path to these outputs.
  • Any signal in to or out of the device that is asynchronous - i.e. doesn't have an associated clock.
    Cheers,
    Alex
    • SK_VA's avatar
      SK_VA
      Hi Thanks for the reply.
  • Yes. Set false paths to any input or output signals that you don't need the timing analyser to consider.
    Cheers,
    Alex
    • SK_VA's avatar
      SK_VA
      Hi Thanks for the Reply.
      How can we determine the signals that doesn't require timing analysis?
