SK_VAOccasional Contributor6 years agoTiming constraints to asynchronous output I have outputs from one FPGA to another FPGA. Outputs are clocked out of one FPGA and is completely combinational in the other FPGA. Can I set false path to these outputs.
a_x_h_75Contributor6 years agoYes. Set false paths to any input or output signals that you don't need the timing analyser to consider.Cheers,Alex
SK_VAOccasional Contributor to a_x_h_756 years agoHi Thanks for the Reply.How can we determine the signals that doesn't require timing analysis?
Recent DiscussionsDK-DEV-AGI027-RA QSPI Verification FailsCyclone 5 SoC FPGA Bank Supply PrerequisiteAGILEX 5 Migration issueTo INTEL - Request for Compliance Data from Analog Devices, IncArria 10 GX RX max intra-differential pair skew
