RLee42
5 years agoTiming constraints on between FPGA and external PLL
I'm using MAX10 to interface with a DSP. The FPGA is the clock provider whose PLL generated a 20Mhz clock to DSP and a 40Mhz clock(fpga_clk) for local use. The DSP uses DSP PLL to generated a 40Mhz l...
EngWei_O_Intel
5 years agoHi Ross Lee
You can refer to doc below as a starting point to understand how to manage metastability using Quartus Prime tools:
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/hb/qts/qts_qii51018.pdf
Eng Wei
