14 years agoTiming constraint problem while using altera ipcore
Hello everyone, I met two problems while using altera ipcores: fir core and fft core(in Straitix III system). The sample clk in my project is 187MHz, and I’ve checked the user guide that both ...
14 years agoUnfortunately I don't know the FIR's internals, I design my own filters without using the megacore. Can the coefficients loading be done in a different clock domain?
Did you have a loot at the timing advisor (Tool menu)? It con give you some ideas about settings to change to increase the fmax. Do you have some options to register the core's inputs and outputs? If yes, enable them.
