12 years agoTiming Constraint problem on set_input_delay
Hello.
I have encountered problems on the following timing constraint. The case is draw in the attachment. I do timing constraint as follows. creat_generated_clock -add -name {SysClk} -source [get_pins {*|inclk[0]}] [get_pins {*|clk[0]}] set_input_delay -clock [get_clocks {SysClk}] -max tAO -reference_pin [get_ports {A[0]}] [get_ports {D [*]}] -add_delay set_input_delay -clock [get_clocks {SysClk}] -max tAO -reference_pin [get_ports {A[1]}] [get_ports {D [*]}] -add_delay set_input_delay -clock [get_clocks {SysClk}] -max tAO -reference_pin [get_ports {A[2]}] [get_ports {D [*]}] -add_delay set_input_delay -clock [get_clocks {SysClk}] -max tAO -reference_pin [get_ports {A[3]}] [get_ports {D [*]}] -add_delay But the timing constraint is ignored for the reason as said in the tool. "Reference pin A[0] is invalid.it is not clocked by the clock specified in set_input_delay/set_out_delay's -clock options." So,why the warning occurs?And how to do timing constraint at this case?11 Replies
Here's a text and document I sent to someone else asking about this. It's not as thorough as I'd normally like(which is why I haven't posted it on the wiki or anything like that), but hopefully gets you going. For flash, I've seen people interface to it really slow, in which case the simple method is easiest. They just don't want some enormous outlier. For trying to get it to run as fast as possible, the more complex method is best. Hopefully it helps.
