12 years agoTiming Constraint problem on set_input_delay
Hello. I have encountered problems on the following timing constraint. The case is draw in the attachment. I do timing constraint as follows. creat_generated_clock -add -name {SysClk} -sourc...
12 years agoThank you!It is very helpful.
I had no idea to remove the warning "No paths exist between clock target "A[0]" of clock "A0_Clk" and its clock source. Assuming zero source clock latency.". And you are right,it is very ugly.I will use option 2.
