12 years agoTiming Constraint problem on set_input_delay
Hello. I have encountered problems on the following timing constraint. The case is draw in the attachment. I do timing constraint as follows. creat_generated_clock -add -name {SysClk} -sourc...
12 years agoOption 2 is much more like constraining two FPGAs talking to each other, whereby you have to just constrain one side to what it can do(I find the output side easiest) and then feed that information to the input side.
On your last comment, the datapath certainly needs to be in the calculation, so something went wrong.
