12 years agoTiming Constraint problem on set_input_delay
Hello. I have encountered problems on the following timing constraint. The case is draw in the attachment. I do timing constraint as follows. creat_generated_clock -add -name {SysClk} -sourc...
12 years agoThank you very much for your reply.I did timing constraint using a way like the option 2.
I used constraint set_output_delay -clock virt_clk -max 0 [get_ports A[*]] to get the max tCO of the A.Then,I calculated the max tCO of the D for the SysClk.And using this way,I worried I forgot to change the calculated value if the tCO of A changed. So then I wanted to use the way with reference_pin.But using the option2 of you,I think there is no necessary to worry about that. By the way,I used the first way to do timing constraint.And I found that the data path doesn't calculate in the tCO of A.So I thought that there is something wrong with it.Right?
