XQSHEN
5 years agoTiming constraint for clock divided by timer
I am doing timing constraint for serial adc ic as below verilog code. clk below comes from system clock from a pll, and divide clock by 250 through timer.
Question 1) :so I define adc_scl...
KhaiChein_Y_Intel
5 years agoHi,
You have to constrain the signals:
Clock - create_clock
PLL - create_generated_clock or derive_pll_clock
adc_sclk - create_generated_clock
adc_data - set_input_delay
adc_sc - set_output_delay, false path and multicycle constraints depending on your design. You may refer to this document https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/an/an433.pdf
KhaiY
