XQSHEN
5 years agotiming constraint for clk using timer
I used timer to divide original system clk.
when doing timing constraint to create generated clock, the source clock, should get_pin from original system_clk or direct from clk_timer register output? It seems clk_timer has 16 register, I don't know which one be used. And there are also some combination logic after clk_timer register.
always @(posedge clk or negedge reset_n) begin
if(reset_n == 1'b0)
clk_timer <= 16'd0;
else if(spi_current_state == SPI_STATE_WRITE)
clk_timer <= clk_timer + 16'd1;
else
clk_timer <= 16'd0;
end
assign spi_inclk = (clk_timer[15:5] >= 16'd2 && clk_timer[15:5] <= (clk_limit[15:5] - 11'd2) && clk_timer[4:0] >= 5'd16);
1 Reply
- XQSHEN
Addtional information: the system clk comes from PLL.
