Timing constrain setting for uart
- 3 years ago
Your observations are correct. You are sampling an asynchronous signal using (I expect) a dual rank clocked synchronizer approach. So there is no timing constraint (setup/hold) applicable on the data input to that input register. It is totally asynchronous.
I have a very similar UART module in a design I have that samples the RX input at 50MHz. In the .sdc file I have:
set_false_path -to [get_ports {UART_*}]
and no other timing constraints on the UART_* inputs.
I’m glad that your question has been addressed, I now transition this thread to community support. If you have a new question, Please login to ‘https://supporttickets.intel.com’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
p/s: If any answer from community or Intel support are helpful, please feel free to mark as solution, give Kudos and rate 4/5 survey
Nurina
