lipingx
3 years agoTiming constrain setting for uart
I am thinking about how to set timing constrain for uart. It's actually sampled by FPGA internnal system clock. For example, if uart baudrate is set 115200 bps, I use FPGA pll clock = 50MHz is quite e...
- 3 years ago
Your observations are correct. You are sampling an asynchronous signal using (I expect) a dual rank clocked synchronizer approach. So there is no timing constraint (setup/hold) applicable on the data input to that input register. It is totally asynchronous.
I have a very similar UART module in a design I have that samples the RX input at 50MHz. In the .sdc file I have:
set_false_path -to [get_ports {UART_*}]
and no other timing constraints on the UART_* inputs.
Nurina
3 years agoHello,
Does above comment help?
Nurina
