Timing closure on Arria 10
I am trying to close timing on an Arria 10 Design (A057K2F40I2). I would like to know if some of the problems I am seeing are device limitations, or just tool issues or operator error.
The first concerns setup time to I/O registers. Here is an example, from Chip Planner:
The delay from the pad to the register input exceeds 5 ns (see below).
This seems a bit high to me, but perhaps mediocre I/O cell performance is a limitation of mid-priced FPGAs.
The second problem regards synthesis results, and the effect therof on timing. We have a block of 32-bit registers, which can be accessed via a PCIe endpoint and Avalon shim interface. There are about 100 - 150 registers, and a 14-bit address. The readback mux for the register block is failing setup time by a significant margin. I would expect the mux for each read data bit to be implemented separately, and the resulting combinatorial circuit would have fewer than 200 inputs. With 6-input LUTs, it should be possible to implement that logic in three or four levels. But I am seeing on the order of 30 levels:
I have added a couple of extra clock ticks and am using a multicycle constraint, but I am still seeing a bunch of paths that don't make it.
Here is the chip planner view for the above mux:
So is this an Arria 10 limitation? I have tried Prime Pro 18.1 and 19.2, as well as Prime Standard 18.2, and I get similar results in each case.
