Seadog
7 years agoTiming closure on Arria 10
I am trying to close timing on an Arria 10 Design (A057K2F40I2). I would like to know if some of the problems I am seeing are device limitations, or just tool issues or operator error. The first co...
IDeyn
Contributor
7 years agoHi Seadog.
In order for the community to help you have to add the archive of your project, it is the easiest way to analyse your issue.
Timing problems are sometimes very complex, and in your case, it could absolutely unreal to help you without additional information from you.
If it is a problem for some reason to attach the whole project, you need to create a simple test version of your project.
Ivan
