Timing Closure for domain crossing between source and divided clocks
Can you show your .sdc and maybe a drawing of your clock network at this point? It's a little hard to visualize.
You're using such low clock speeds that it's surprising that you'd run into any timing issues, though I guess the hold timing issues may be more of a trampling of the next clock cycle by a previous one.
Happy New Year and thanks for your help. I am attaching the sdc file and a pdf showing the clock tree structure. The clock definitions from the sdc are pasted below the dotted line
Jim
# Create Clock
create_clock -name {clock_in_3p6864mhz} -period 271.000 -waveform { 0.000 135.000 } [get_ports {clock_in_3p6864mhz}]
create_clock -name {cpld_master_clock} -period 542.000 -waveform { 0.000 271.000 } [get_nets {cpld_master_clock}]
# Create Generated Clock
create_generated_clock -name {uart_rx_clock} -source [get_nets {cpld_master_clock}] -divide_by 2 -master_clock {cpld_master_clock} [get_registers {clock_divider:CDIV2|clk_out}]
create_generated_clock -name {uart_tx_clock} -source [get_nets {cpld_master_clock}] -divide_by 32 -master_clock {cpld_master_clock} [get_registers {clock_divider:CDIV3|clk_out}]
create_generated_clock -name {millisec_clock} -source [get_nets {cpld_master_clock}] -divide_by 1920 -master_clock {cpld_master_clock} [get_registers {clock_divider:CDIV4|clk_out}]
create_generated_clock -name {heartbeat_clock} -source [get_nets {cpld_master_clock}] -divide_by 3840 -master_clock {cpld_master_clock} [get_registers {clock_divider:CDIV5|clk_out}]
- sstrell5 years ago
Your second create_clock should be a create_generated_clock since it's sourced from the input clock. And you should always try to use get_pins for your targets instead of get_nets. You can use the Name Finder through the Quartus Text Editor SDC GUI dialog boxes to find the correct targets.
- jch44165 years ago
Thanks for your reply. I am trying to implement your advice, but so far unsuccessfully.
I used the post-fit netlist viewer to try to figure out the correct names. Here are the constraints I created in the Timing Analyzer using the post-fit names:
create_generated_clock -name {cpld_master_clock} -source [get_ports {clock_in_3p6864mhz}] -divide_by 2 -master_clock {clock_in_3p6864mhz} [get_pins {CDIV1|clk_in_count[0]|regout}]
create_generated_clock -name {uart_rx_clock} -source [get_pins {cpld_master_clock|combout}] -divide_by 2 -master_clock {clock_divider:CDIV1|clk_out} [get_pins {CDIV2|clk_out|regout}]
create_generated_clock -name {uart_tx_clock} -source [get_pins {cpld_master_clock|combout}] -divide_by 16 -master_clock {clock_divider:CDIV1|clk_out} [get_pins {CDIV3|clk_out|regout}]
create_generated_clock -name {millisec_clock} -source [get_pins {cpld_master_clock|combout}] -divide_by 1920 -master_clock {clock_divider:CDIV1|clk_out} [get_pins {CDIV4|clk_out|regout}]
create_generated_clock -name {heartbeat_clock} -source [get_pins {cpld_master_clock|combout}] -divide_by 2 -master_clock {clock_divider:CDIV1|clk_out} [get_pins {CDIV5|clk_out|regout}]The Quartus fitter rejected all but the first one. The error messages are below:
Info (332104): Reading SDC File: 'Mk1_Safety_Unit_CPLD.out.sdc'
Warning (332087): The master clock for this clock assignment could not be derived. Clock: uart_rx_clock was not created.
Warning (332034): Specified master clock: clock_divider:CDIV1|clk_out not found on or feeding the specified source node: cpld_master_clock|combout
Warning (332087): The master clock for this clock assignment could not be derived. Clock: uart_tx_clock was not created.
Warning (332087): The master clock for this clock assignment could not be derived. Clock: millisec_clock was not created.
Warning (332087): The master clock for this clock assignment could not be derived. Clock: heartbeat_clock was not created.
Warning (332060): Node: clock_divider:CDIV1|clk_out was determined to be a clock but was found without an associated clock assignment.
Warning (332060): Node: clock_divider:CDIV3|clk_out was determined to be a clock but was found without an associated clock assignment.
Warning (332060): Node: clock_divider:CDIV2|clk_out was determined to be a clock but was found without an associated clock assignment.
Warning (332060): Node: clock_divider:CDIV5|clk_out was determined to be a clock but was found without an associated clock assignment.
Warning (332060): Node: clock_divider:CDIV4|clk_out was determined to be a clock but was found without an associated clock assignment.I think I'm on the right track, but I don't yet have the names that the fitter wants to see for the -source_clock and/or -master_clock fields.
I am attaching a screenshot of the post-fit netlist viewer output showing the output of CDIV1 and the global buffer that follows it. The global buffer output feeds dividers CDIV2-5 but what should I use as the source pin in the constraints for CDIV2-5? Apparently cpld_master_clock|combout isn't right.
I made some progress. Saw an error in the target pin for the cpld_master_clock and corrected it. Also changed the source clock definition for each divider from -source [get_pins {cpld_master_clock|combout}] to -source [get_nets {cpld_master_clock}].
Why would get_pins{ } be better than get_nets{ }?
Quartus was happy with this and all the synchronization warnings disappeared.
The constraints are now:
# Create Clock
#**************************************************************create_clock -name {clock_in_3p6864mhz} -period 271.000 -waveform { 0.000 135.000 } [get_ports {clock_in_3p6864mhz}]
#**************************************************************create_generated_clock -name {cpld_master_clock} -source [get_ports {clock_in_3p6864mhz}] -divide_by 2 -master_clock {clock_in_3p6864mhz} [get_pins {CDIV1|clk_out|regout}]
create_generated_clock -name {uart_rx_clock} -source [get_nets {cpld_master_clock}] -divide_by 2 -master_clock {cpld_master_clock} [get_pins {CDIV2|clk_out|regout}]
create_generated_clock -name {uart_tx_clock} -source [get_nets {cpld_master_clock}] -divide_by 32 -master_clock {cpld_master_clock} [get_pins {CDIV3|clk_out|regout}]
create_generated_clock -name {millisec_clock} -source [get_nets {cpld_master_clock}] -divide_by 1920 -master_clock {cpld_master_clock} [get_pins {CDIV4|clk_out|regout}]
create_generated_clock -name {heartbeat_clock} -source [get_nets {cpld_master_clock}] -divide_by 2048 -master_clock {cpld_master_clock} [get_pins {CDIV5|clk_out|regout}]
