timing analyzer relationship
information is a scarce here, so it's just wild guessing:
is it possible that paths 13 and 14 are lauched by an FF with inverted clock ? some unwanted logic in the clock path perhaps?
It cannot be started by the FF of the inverting clock.
There is some unnecessary logic for the clock path.
Is Relationship sometimes not set correctly if there is unnecessary logic for the clock path?
- Michael194 years ago
Any logic in the clock path will add some delay to the clocks latency values, even if it is not inverting it.
And if this logic perchance inverts the clock, i would assume that this adds half a clock period in addition.
If it is unneccessary logic, get rid of it.
Else try at least to analyze this logic. Can't you produce a timing report which shows your clock-paths in detail?
Try to see how the tool is implementing this in the fpga's fabric. If it for some reason can't use the specialized clock routing ressources to connect to your FF, you get tons of unnecessary delay.
