11 years agoTime to start learning FPGA! How to choose the correct FPGA for this project?
Hi all! I hope this isnt a too booring newbie post, but I didnt know really where to start. My questions are many and the road to learn FPGA seems long, but please bare with me. My hobby...
11 years agoThank you for your input!! Thats really helpful :D.
Actually the DE0 Nano board looks awesome, and with that one I could start learning right away instead of making my own pcb first.. alot better. I did not know there was a developerboard at such a affordable price! I will give the DE0 manual a proper read after lunch and probably make my order! Thou just looking at it I guess I still need to make a seperate cart for the voltagetransitions between the DE0 and the Poject pcb.. But its probably well written in the manual if its needed! Thanks so far!!! What an awesome start! :D --- Quote Start --- Well, I think it is really hard work to start with such a big project, but why not? At least you have the code for implementing the CPU in a FPGA. So I think this will make things more easy. To choose the right FPGA you mainly have to know how many Logic Elements (LEs) are used by the CPU-Core. Normally this Information will be provided with the code. Take this number and double it for design safety, further extensions .... bla bla and so on .... and search for FPGAs which provide AT LEAST this number of LEs The next thing you have to know is how many pins and clocks you will need. But I think nearly all Cyclone FPGAs with enough LEs should also have enough pins. Now think about the speed grade and the temperature range. Well, for a Z80 with 8 - 20 MHz you can also choose a speed grade of '8' and for home usage the commercial temperature (0 - 85°C) range should also fit your needs. But if you have the money, you can also choose a higher speed grade of '6' and the industrial or automotive temperature range which supports up to 125°C (and down to -40°C). Some other suggestion: Why don't you try the DE0nano board? It comes with a mid-range Cyclone IV, some periphery, a lot of IOs and the only thing you have to do is to build an adapter from the IO-Pins to the 40p DIP Socket. This board costs about 90$ and can be programmed via USB. I think 22000 LEs could be enough for a small CPU-Core. For a overview on cyclone devices see: Cyclone II: http://www.altera.com/literature/hb/cyc2/cyc2_cii5v1.pdf Cyclone III: http://www.altera.com/literature/hb/cyc3/cyc3_ciii52001.pdf Cyclone IV: http://www.altera.com/literature/hb/cyclone-iv/cyiv-51001.pdf --- Quote End ---
