16 years agotime limited sof file
I have still not purchased the license for NIOS II IP. So right now i get the _time_limited.sof file output from the Quartus 9.0 sp1 edition. My question is can the time_limited.sof file be converted to flash format using the sof2flash utility ? Apparantly I am getting an error during conversion process .. something that looks as follows # Creating .flash file for the FPGA configuration "$SOPC_KIT_NIOS2/bin/sof2flash" --offset=0x0 --input="$SOPC_KIT_NIOS2/examples/v hdl/DBC3C40/epcs_boot1/DBC3C40_standard_time_limited.sof" --output="DBC3C40_stan dard_time_limited.flash" Info: ******************************************************************* Info: Running Quartus II Convert_programming_file Info: Command: quartus_cpf --no_banner --convert C:/altera/90sp1/nios2eds/exampl es/vhdl/DBC3C40/epcs_boot1/DBC3C40_standard_time_limited.sof DBC3C40_standard_ti me_limited.rbf File C:/altera/90sp1/nios2eds/examples/vhdl/DBC3C40/epcs_boot1/DBC3C40_standard_ time_limited.sof contains one or more time-limited megafunctions that support th e OpenCore Plus feature that will not work after the hardware evaluation time ex pires. Refer to the Messages window for evaluation time details. Info: SRAM Object File C:/altera/90sp1/nios2eds/examples/vhdl/DBC3C40/epcs_boot1 /DBC3C40_standard_time_limited.sof contains time-limited megafunction that suppo rts OpenCore Plus feature -- Vendor: 0x6AF7, Product: 0x00A2 Info: SRAM Object File C:/altera/90sp1/nios2eds/examples/vhdl/DBC3C40/epcs_boot1 /DBC3C40_standard_time_limited.sof contains time-limited megafunction that suppo rts OpenCore Plus feature -- Vendor: 0x6AF7, Product: 0xBCEC Info: SRAM Object File C:/altera/90sp1/nios2eds/examples/vhdl/DBC3C40/epcs_boot1 /DBC3C40_standard_time_limited.sof contains time-limited megafunction that suppo rts OpenCore Plus feature -- Vendor: 0x6AF7, Product: 0xBCE1 SOF Data item missing input file Error: Convert Programming Files was NOT successful -- refer to messages that ap pear above this message for more information Can somebody please help me out Best regards, Rohit1 Reply
No.
Time limited means that you can not create files that can be used for production purposes to enable you to sell your design instead you need a connection between your pc and the target.
