14 years ago
This noob needs help...
Hello everyone,
I've recently started using ModelSim Altera Starter Edition 10.0c and I'm trying to get simulate a really simple "AND" gate. Here's my code:
library ieee;
use ieee.std_logic_1164.all;
entity mygate is
  port( x,y : in std_logic;
          z     : out std_logic);
end entity mygate;
architecture here of mygate is
begin
z <= (x and y);
end architecture here;
It compiles fine but I have no clue how to set boolean values to x and y and run the simulation. I've been trying for the last few hours and I'm completely lost. Please help.
    You can detatch any of the windows and move them around as you want. Otherwise just get another monitor unfortunately.
    Thanks. Everything compiles ok. But how do I run the simulation now? I tried adding the objects x, y, and z to the wave graph but their values are just described as "U"...
    never mind I got it. thanks.
    One last thing... all my windows are filling up the whole screen, but I would prefer to have them all take up less space so I can see more than one window at once. For example I want to see the project tab and mygate.vhd tab at once on the screen. How do I do this?
    oops, remove the semicolon from the end of the UUT line, and put one at the end of the port map.
    The UUT is just a name given to the instantiated entity. IT can be any identifier you want - UUT standard for unit under test.
    I've tried this code as an additional vhdl file to he original one i posted:
    library ieee;
    entity mygate_TB is
    end entity mygate_TB;
    architecture RTL of mygate_TB is
    signal x,y,z : std_logic;
    begin
    UUT : entity work.mygate;
    port map (
    x => x,
    y => y,
    z => z
    x <= '0', '1' after 100 ns, '0' after 200 ns;
    y <= '1',                   '0' after 300 ns;
    end architecture RTL;
    I've corrected the "mygate_TB" problem and get this error when compiling:
    vcom -work work -2002 -explicit C:/altera/11.1/modelsim_ase/test.vhd
    Model Technology ModelSim ALTERA vcom 10.0c Compiler 2011.09 Sep 21 2011
    -- Loading package STANDARD
    -- Loading package TEXTIO
    -- Loading package std_logic_1164
    -- Compiling entity mygate_TB
    -- Compiling architecture RTL of mygate_TB
    -- Loading entity mygate
    ** Error: C:/altera/11.1/modelsim_ase/test.vhd(11): (vcom-1035) Formal port "x" has OPEN or no actual associated with it.
    ** Error: C:/altera/11.1/modelsim_ase/test.vhd(11): (vcom-1035) Formal port "y" has OPEN or no actual associated with it.
    ** Error: C:/altera/11.1/modelsim_ase/test.vhd(12): near "port": syntax error
    ** Error: C:/altera/11.1/modelsim_ase/test.vhd(21): VHDL Compiler exiting
    Hmmm... what's going on? I don't understand what the "UUT" part means. I'm just looking for a simple simlulation which will test the gate.
    you need to create a testbench - this is another VHDL entity that instantiates your and gate and sets the input values. It does not have to be synthesisable - something like this:
    library ieee;
    entity mygate_TB is
    architecture RTL of mtgate_TB is
    begin
      port map (
        x => x,
        y => y,
        z => z
