lambert_yu
Contributor
2 years agoThere's minimum pulse violation for IOPLL under source synchronous operation mode
Hi, I am facing one issue when I design the source synchronous lvds project. case: quartus II : 18.0.0 standard speed : 1.6Gbps; PLL : use external PLL ref clk for PLL: 800Mhz op...
- 1 year ago
May I know which LVDS functional mode are you using?
You will need to use the PLL compensation mode provided in the User Guide, for the corresponding LVDS functional mode.
Richard Tan
RichardT_altera
2 years agoHi,
Do you need any further assistance from my side?
Richard Tan
- lambert_yu2 years ago
Contributor
Hi, RichardTanSY
I hadn't received any helpful information for this issue. Now current solution for this issue, I changed the PLL mode (from source sync -> direct mode). But for above issue, I expect that I could get the root cause.
Lambert
