12 years agothe Quotient is floating point in vhdl
hi all if i want to divide two numbers and i know the result would be float . what can i do it and how to specify the output from division thanks a lot.
12 years agoFloating point is most likely not the best solution for your problem, a 8.8 fixed point number sounds like a better idea. You easily get it by multiplying the dividend with 256 before the division.
8 fractional bitsis just a first guess, you have to find out the required accuracy for your problem. I notice that your ideal result is already several percent off by truncating the divisor of 12.5 to 12. Of course, this point could be corrected in a fixed point algorithm, too.
