12 years agothe Quotient is floating point in vhdl
hi all if i want to divide two numbers and i know the result would be float . what can i do it and how to specify the output from division thanks a lot.
12 years agowhat are the two operands? diving two integers gives you an integer and remainder result (if you use the IP core). If you use correct scaling, you can get a fixed point output. You only get a floating point result if both inputs were floating also.
