Nordog
4 years agoThe Quartus prime software quit unexpectedly
This has not been fixed in Quartus Lite and I can't continue my project without the fix
RichardT_altera
4 years agoWhen the Quartus Prime software quit unexpectedly window pop ups, you should see an internal error in the "Preview report".
example: Internal Error: Sub-system: PTI, File: /quartus/tsm/pti/pti_tdb_builder.cpp, Line: 1331
You may checkout our Intel FPGA Knowledge Base webpage to check if there is available solution to the respective internal error.
If not, you will need to share us design .qar file to duplicate this error.
As without duplication of the error from our side, it would be hard to find a workaround/solution for internal error issue.
Which Quartus version and OS system that you are using?
Richard Tan
Nordog
4 years agoI think I did this right. Sharing my File
