17 years agoThe problem of Board Description Editor
HI,I can't find Board Description Editor in SOPC8.1,can anyone help me in sorting out this issue?but in the release of 6.1 or below,we can find it.
Jack,U are so kind!Thanks very much!
BTW,can u tell me how to set the Reset address and Exception Address. I save software code in flash and system contents in EPCS1.So i set reset address to ext_flash(name of CFI),but i don't know how to set Exception Address? HANDSOME - Altera_Forum
Correct. Just forget about the board description. You'll never need it again.
Jake - Altera_Forum
Hi,thanks very much for your reply!
U mean i don't need to start a new board description?Just add the useful compents needed? Thanks again! - Altera_Forum
Yes, basically you don't need to worry about a board description any longer. I always thought it was a little silly anyway. Now the tools just look at your SoPC description to determine what flash devices are available.
Jake - Altera_Forum
The Board Description Editor was removed. It was foretold in chapter 7 of the Quartus II handbook from March 2007...
http://www.altera.com/literature/hb/qts/qts_qii54015.pdf "Board descriptions and the board description editor are deprecated features in SOPC Builder v7.0. These features will be removed in a future version of SOPC Builder. Do not use these features for new projects" Just use the pin planner to make your pin assignments. Best Regards,
