16 years agoThe MSEL pins are powered by VCCINT
1)I am using EP3C25E144,it has MSEL[2..0],from tha datasheet see that "The MSEL pins are powered by VCCINT",but when I design the PCB ,i only saw that keep them '101' is Fast Active Serial Fast (AS F...
16 years ago --- Quote Start --- but then i saw that the high level should be VCCINT (1.2V) --- Quote End --- Where do you see this in a datasheet? The datasheet says "The MSEL pins are powered by VCCINT.", which in my understanding means, the input buffers are supplied by VCCINT. I don't see a statement different from this suggestion: --- Quote Start --- Altera recommends connecting the MSEL pins to VCCA or GND depending on the MSEL pin settings. --- Quote End ---
