15 years agoThe FPGA doesn't work
Hello eveyone: I'm designing a system of cycloneiii ep3c10e144. The configure chip EPS16 can be written but the FPGA does not work.Could anyone help me checking the scheme pls? The attach is the s...
15 years agoI'm guessing you are talking about accessing the flash through the J3a connector?
If you used JTAG instead and load a SFL image, you'd be able to test the connection between the FPGA and the flash configuration device.
