9 years agothe difference between a general clock inputs
I am designing a new board with 5CEFA5F23I7 device. Can you please explain what is the difference between a general clock input for example pins : H16,H15 - CLK11p,CLK11n to the clock in...
9 years agoDifferent pins drive different clocks in different regions. See figure 4-1 here:
https://www.altera.com/content/dam/altera-www/global/en_us/pdfs/literature/hb/cyclone-v/cv_5v2.pdf Then, skip to Figure 4-18 in the same document to see how different pins connect to different PLL's. Altera provides a design guide: https://www.altera.com/content/dam/altera-www/global/en_us/pdfs/literature/an/an662.pdf The section "Clock Planning" on page 26 says: --- Quote Start --- Understand your device’s available clock resources and correspondingly plan the design clocking scheme. Consider your requirements for timing performance, and how much logic is driven by a particular clock --- Quote End --- Which is a fancy way of saying: for your application, maybe you don't care at all about the differences between the clock pins. Or maybe you care A LOT!
