CAlex
Contributor
3 years agoThe clock source of the cycloneVsoc board and its settings
Hi during the HPS programmming, I noticed the clock source in GHRD is a 50MHZ clock. And the board had a DIP switch to control the clock source. Could you please tell me where that clock sou...
mabdrahi
Contributor
3 years agoHi,
You can use signal tap tools that available in quartus. If your main problem is solved, i will close this case
