18 years agothe clock divider with enable using verilog
i am working with EPM570T100I5,which has no PLL,i want to get a 1MHz clcok,the global clock is 50MHz.i have read the posts about clcok divider,the enable clock is a good way,but i am a newbie,i didno...
18 years ago --- Quote Start --- H simplora, try the code below as to pin-t0-pin delay. This is natural and is defined as the delay of combinatorial elements from an input pin to output pin. It is not much relevant in your case as you are not going to use clk_o as an external pin... -- prbs generator library IEEE; use IEEE.std_logic_1164.all; entity prbs_generator is port( reset : in std_logic; clk : in std_logic; enable : in std_logic; data : out std_logic_vector(23 downto 0) ); end entity prbs_generator; architecture rtl of prbs_generator is signal shift_reg : std_logic_vector(33 downto 1); begin process(reset, clk) begin if(reset = '1')then shift_reg <= '0' & x"28EA5CB1"; -- seed value data <= (others => '0'); elsif(rising_edge(clk))then if(enable = '1')then -- prbs generator shift_reg(1) <= shift_reg(33) xor shift_reg(20); shift_reg(33 downto 2) <= shift_reg(32 downto 1); -- output data <= shift_reg(24 downto 1); end if; end if; end process; end architecture rtl; --- Quote End --- thx again.i code s simple AND gate,like: out1 = in1 & in2,i found the out1 is delay about 6ns to in1 and in2,how to explain this.
