18 years agothe clock divider with enable using verilog
i am working with EPM570T100I5,which has no PLL,i want to get a 1MHz clcok,the global clock is 50MHz.i have read the posts about clcok divider,the enable clock is a good way,but i am a newbie,i didno...
18 years ago --- Quote Start --- Hi simplora(nee ha), I believe your counter code is correct. As to enable, the code from pletz explains it well for the given assignment. I am sorry I haven't use verilog for quite sometime(I used it in 2004/006 and can't remeber...). I know vhdl more than my mother language. If you wish I can do that in vhdl... regards Kaz --- Quote End --- hi,i do not know the VHDL,but i can compiler the VHDL code,and i think the RTL is simple,so please post some VHDL code which can be compilered,and another question: how can i understand "pin to pin delay", i compiler the code i posted above,and do the time simulation,i find the delay is about 12ns between clock rising edge and the clk_o,i don't know where the delay comes from? THX!
