18 years agothe clock divider with enable using verilog
i am working with EPM570T100I5,which has no PLL,i want to get a 1MHz clcok,the global clock is 50MHz.i have read the posts about clcok divider,the enable clock is a good way,but i am a newbie,i didno...
18 years agoHi simplora(nee ha),
I believe your counter code is correct. As to enable, the code from pletz explains it well for the given assignment. I am sorry I haven't use verilog for quite sometime(I used it in 2004/006 and can't remeber...). I know vhdl more than my mother language. If you wish I can do that in vhdl... regards Kaz
