18 years agothe clock divider with enable using verilog
i am working with EPM570T100I5,which has no PLL,i want to get a 1MHz clcok,the global clock is 50MHz.i have read the posts about clcok divider,the enable clock is a good way,but i am a newbie,i didno...
18 years ago --- Quote Start --- In accordance with your post, I wrote the following code,could tell me is it right?is it the enable clock divider? THX very much. module divider (clk, rst_n, clk_o); parameter TIMECONST_49 = 6'b110001; input clk; input rst_n; output reg clk_o; reg [5:0] div_50; reg en_50; always @ (posedge clk or negedge rst_n) begin if (!rst_n) begin div_50 <= 6'b000000; en_50 <= 1'b0; end else begin if (div_50 == TIMECONST_49) begin div_50 <= 6'b000000; en_50 <= 1'b1; end else begin div_50 <= div_50 + 6'b1; en_50 <= 1'b0; end end end always @ (posedge clk or negedge rst_n) begin if (!rst_n) begin clk_o <= 1'b0; end else if (en_50) clk_o <= ~clk_o; end endmodule --- Quote End --- Hi simplorer, the signal is intended to be used as enable for for the FF's. e.g: always @(posedge clk) begin if (enable) ff_sig <= in; end
