[Test] The DC_FIFO issue of Cyclone 10 GX devices
Hello Guys,
We are using 10CX220F780 and 10CX105F780 devices now. They are communicating thru XCVR. So one DC_FIFO is realized between RX received data and user logic fabric.
This DC FIFO operation always has problem during the first operating. But it will be normal during the second operating.
As the above image indicates, RX get data from XCVR and put them to FIFO. The write is ok, however, the reading has problem. Because the first read data is ZERO, this causes the following reads all halt.
I apply one more same operation, now it's ok, as following image:
As above image indicates, one data is put into FIFO, and it will be read out from this FIFO in time.
But why always the first time operating is not correct after power-up or re-configuring FPGA?
I did one test: FIFO's Rdreq is fix to high level. Then I got the following result:
As above image indicates, the first data x"40000000" can't be written into FIFO. So I always got ZERO for the first data. Buy how this can happen? I kept detecting more deeply, as following image
As above image indicates, after Wreq valid, 2 clock cycles later, Usedw will change, and 2 more clock cycles later, empty signal will be changed to low level.
This is the problem. Usedw and empty signals are changed too fast. I checked normal timing, UsedW should be changed 3 clock cycles later after Wreq valid, and empty should be changed 5 clock cycles later after Wreq valid.
Why can this happen? And always happen one time after power-up.
- dandanlau
I have a couple of questions.
- I assume this does not show up in simulation?
- Has the FIFO been out of reset for a long time before the first wrreq?
- Can you delay the first wrreq for a couple of clock cycles?
- czy_test
Moderator
Thank you for providing the detailed description and waveforms. I assume that the FIFO is configured to Normal mode.
This behavior typically occurs due to transceiver clock instability during power-up/reset or premature read requests before pointer synchronization is complete.
Probable root cause & recommendations:
- Transceiver Clock Stability & Reset Sequencing (`rx_ready`):
- At power-up/reconfiguration, the transceiver CDR and PLL calibrate, during which `rx_clkout` can experience glitches or unstable frequencies before locking.
- Ensure the DCFIFO `aclr` (asynchronous reset) is held asserted until the Transceiver PHY Reset Controller asserts `rx_ready` (and both `wrclk` and `rdclk` are stable).
- After `aclr` is deasserted, wait at least 3 to 5 clock cycles before asserting `wrreq`.
- Read Request (`rdreq`) Gating:
- Do not tie `rdreq` permanently high (`1'b1`). Asserting `rdreq` while `rdempty` is high causes FIFO underflow:
- In Normal Mode: Reading while empty results in invalid/zero data.
- Always qualify your read logic: only assert `rdreq` when `rdempty == 1'b0`.
- Is it possible to bring the DC_FIFO signals 'aclr' and 'wrclk' also in the signal tap?
For more details on reset sequencing and timing requirements, please refer to the FIFO Intel FPGA IP User Guide on Altera.com.
Altera Applications Support- czy_test
Moderator
Thank you for the reply
I think this issue doesn't relate with power-up issue. For our board has been powered on for long time when we want to operate FIFO. We have one look up table required to send to object FPGA from top-level thru DAQ and tranceiver. So you can see from previous SignalTap II images. The FIFO writing time interval is about 100 ns (Actually, our DAQ speed is only 10MHz.), and our system clock frequency is 100MHz. This look up table can be written correctly after this issue. This problem only happens when power-up/download new program. It means that we have to write this look up table two times, because the first time has this problem. We can't repeat this issue after it appears one time. If we want to repeat this issue, we have to power-up again, or download program again.
I apply 'rdreq' with '1' just for verifying FIFO writing operation. Our normal 'rdreq' signal is generated as you mentioned.
BTW, we don't open 'aclr' port for FIFO. And I don't think we can check 'wrclk' from signaltap, for sgnaltap clock frequency is equal to 'wrclk'.
Best regards
