18 years agoTcp_ip, Sopc
hello,
i have a bord STRATIX II EP2S60, i use quartus 2 v7.2. i would like to use nichestack tcp/ip for nios 2, I don't know if i must use the MicroC/OS for this or i can avoid it (i don't know if i have the choice or no). thanks.14 Replies
Hi, on an other project, I try to use InterNiche Stack in superloop mode and I have the same problem noticed in http://www.alteraforum.com/forum/showpost.php?p=9433&postcount=8 (post# 8) but with a DP83848C PHY.
--- Quote Start --- prepped 0 interfaces, initializing... inet startup error: unable to find any working interfaces panic: IP dtrap - needs breakpoint --- Quote End --- Do I need to use ETH_OCM_INSTANCE() elsewhere ? i use quartus and nios ii ide 9.0sp2 , internichestack in superloop mode, ethernet opencore mac (and dp83848c phy) - Altera_Forum
I found the mistake : :D
I use a crossed cable between PC <-> board and DHCP was enabled. simply disable dhcp and it seems to work. - Altera_Forum
--- Quote Start --- I found the mistake : :D I use a crossed cable between PC <-> board and DHCP was enabled. simply disable dhcp and it seems to work. --- Quote End --- Hi, how can you make it work. And what do you mean disable DHCP. I tried to make it by set the variable *use_dhcp = 0; but it didn't work for me. I am still getting the error inet startup error: unable to find any working interfaces (using cross cable PC and DE2-70 board) Thanks - Altera_Forum
I am using the 13.1 version of both NIOS-II EDS and the Quartus-II Programmer. I am also seeing the same problem described in this thread. Ethernet device is not being detected. The version of BSP that I have calls "ALTERA_AVALON_SGDMA_INIT" from "alt_sys_init()" which looks like a ethernet subsystem but I still don't see any ethernet devices.
Has this issue been resolved by anybody? Can somebody provide me with some pointers? Thanks, -Srinath
