14 years agoTCL script usage
I have an NCO function that plays waveforms from an sp ram that I initialize using a mif file. I then recapture the waveform using an ADC and store it in another SP ram. I would like to test differen...
14 years agoHi Matt,
--- Quote Start --- Right now I have two RAMs, one with a waveform for the DAC, another connected to the ADC. I can load a waveform into the DAC RAM and see it get filled into the ADC RAM. Im now about to write up some TCL scripts that use the 'in-system' memory content editor. Is this a bad way of doing things? I know it is quick and dirty, but it seems to be working. --- Quote End --- If there are Tcl commands for the in-system memory editor, then by all means, go for it. I haven't used that particular tool, so can't comment on how efficient it is. If you want to have a design that you can also simulate in Modelsim, then take a look at the JTAG components, or ask, and I'll show you how to use them. Cheers, Dave
