8 years ago
TCL console path initialization
I am trying to run commands in the Quartus 16.0 Tcl console window. Commands like quartus_map result in that the command name is invalid.
I am running on Windows and have edited the PATH variable to include C:\altera\16.0\quartus\bin64 which is where the executables are located on my machine. I am able to run the commands from the nios shell but from the Quartus GUI tcl console I get the above error. So I am unsure how to setup whatever initialization is done when Quartus is launched so that it can find these commands or pickup the Windows PATH environment variable
Dave
    Hi Dave,
    --- Quote Start ---
    --- Quote End ---
    Refer the “quartus_map” from page number 2-45,
    We can runs one of the command-line executables, such as quartus_map or quartus_fit. If the -args option is specified, the arguments are passed to the command-line executable.
    Refer the “execute_module” from page number 3-103,
    Check example on page number 3-270.
    https://www.altera.com/content/dam/altera-www/global/en_us/pdfs/literature/manual/tclscriptrefmnl.pdf
    Best Regards
    Vikas Jathar
    Hi Dave,
    "quartus_map" you can use in the command line. (Altera Nios2 Command Shell)
    In the Quartus TCL console the "execute_flow -compile" will do a full compilation.
    You can look at the documentation (Quartus II Handbook, TCL-Scripting) or enter in the command line:
    "quartus_sh --qhelp" for detailed informations.
    Jens
