8 years agoTCL console path initialization
I am trying to run commands in the Quartus 16.0 Tcl console window. Commands like quartus_map result in that the command name is invalid. I am running on Windows and have edited the PATH varia...
8 years agoHi Dave,
"quartus_map" you can use in the command line. (Altera Nios2 Command Shell) In the Quartus TCL console the "execute_flow -compile" will do a full compilation. You can look at the documentation (Quartus II Handbook, TCL-Scripting) or enter in the command line: "quartus_sh --qhelp" for detailed informations. Jens
