14 years ago
[Target Connection]: No Nios II target connection paths were located. Check connectio
Hi all.
I'm running quartus web-edition 12.0, on win7 64 bit.
I'm using cyclone II starter kit.
i ran through the nios2 hardware tutorial and downloaded the software correctly.
after that i tried to modify the qsys, by adding a simple rs232 uart.
thats when i first got the message.
then i started the tutorial from scratch, deleted the old files, but i still have the same problem!
i downloaded the correct .sof.
i checked - i have only one cable installed.
i checked the forum, for similar problems, but none of the solutions worked for me. :(
anyone have something similar?
    i know that no one can see what i have, thats why i asked if anyone have something similar.
    do you have a license for NiosII?
    if you don't, don't you get xxxx_timelimited.sof on your folder?
    # you know, people who are not actually with you can not tell what is wrong exactly.
    # this is a help as much as I can do.
